Wheel hop
Old 05-11-2004, 12:28 AM
  #16
L.O. Green95Z's Avatar
The QA-1 front shocks have threaded bodies so you can adjust ride height.
It rides so much better with the front higher but if it is hurting my launches I will lower it back down. My front end was about as low as the white car before I raised it up. I was hitting the air dam and headers on the ground on every little bump.
I launch at about 5000-5500 with about 340 rwhp. I am just surprised it was spinning as badly as it was.
Thanks for all the help guys hopefully I will get this all sorted out so I can worry about making a little more power
L.O. Green95Z is offline
Old 05-11-2004, 12:52 AM
  #17
Xride's Avatar
you got a 12 bolt? or still on the stock 10?
I'm assuming 12 or 9", but jsut asking
Xride is offline
Old 05-11-2004, 12:09 PM
  #18
12 bolt with a spool and 4.56 gears.
I didnt get along with 10 bolts I broke 3 axles, 2 of them while running nittos and busted up a spider gear in the posi.
force10
08-10-2015 08:30 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
SAR2K
09-01-2002 10:49 AM
wytblur
08-05-2002 02:03 PM
Quick Reply: Wheel hop
