Wheel hop and occasional thunking under frame
I understand LCA'a are sometimes used to correct this problem. I was also told to look into possible ladder bars. Can someone give some good advise as to which will do the trick, including manufacturers info too. Thanks alot.
G
G
Re: Wheel hop and occasional thunking under frame
i fixed wheel hop with spohn lca's and got the relocation brackets to further fix it.
then i fixed my tranny clunking around with a prothane tranny mount.
LCA relocation brackets and adj. panhard rod fixed my wheel hop problem. I still get it on large dips and hopefully replacing my stock LCA's will eliminate all the wheel hop
G
G
Originally Posted by tomatocity
I fixed the thunking by replacing the rear motor mount with a stock unit. The thunking is caused by the motor mount collaspsing over a period of time and the exhaust hits the tunnel brace. I have a convertible. I am sure the poly mount will last longer than the stock part.
BTW that's for the help guy's
Is that possible with only 7000 miles on the car?
7000 miles! let the dealership resolve the problems. though beware. Before I purchased my now car, it was at the dealship for repair and one of the technicians wrecked it.
probably not, but I would take a look and see how close the exhaust is to the tunnel brace. it should at least have a 1/2 inch clearance.
I tried that when I had the car dynotuned with my mods, and they asked what the hell did you do to this thing? There computer couldn't read my PCM, thus couldn't fix it. Besides the way it growled, they knew I went one step beyond any warranty service. In addition the exhaust isn't stock either. I just need to get to a lift so I can figure out what is hitting what.
Originally Posted by crzhrs
Rear motor mount? Am I missing something here? My car has a bad thump when I dump the clutch that I can't figure out. Put a brand new poly trans mount on and still have the thump. Bout to lose my mind trying to figure it out.
I thought only the convertibles have an x-brace. If you are talking about the tunnel brace it was removed before I bought the car.(A missing tunnel brace couldn't cause that thump could it?) I have Mac headers and stock exhaust.... hangs real low. Don't think that is a problem.
I will take a look at the exhaust but I am still confused on the rear motor mount deal. I thought there was only one on each side. I forgot to mention my car has been lowered 2". So about the post hijack Gearslammer.
99TransAmWS6
02-12-2015 07:23 PM
squarehead
01-15-2015 07:02 PM
wytblur
08-05-2002 02:03 PM
