Wheel Hop problems... HELP
Okay, I have a 95 Z28 Camaro, I just installed a Moser 12 bolt with 33 spline axels, eaton posi and a 4:11 gear. I also added a torque arm from spohn. ...Now i have a problem with bad WHEEL HOP. when im spinning in first... say i dump the clutch... all it does is ERRT ERRRT EERRT ERRRT ..NOT the usual ERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRT.
what can i do to fix this? my suspension is stock... any aftermarket parts that will help? I heard "ladder bars" will do the trick... but i dont even know what those are!
help!
help!
Re: Wheel Hop problems... HELP
lover control arms - $100
relocation brackets - $75 for weld in, $100 for bolt in
that should do the trick.
make sure your pinion angle is correct with the new torque arm.
i suggest www.bmrfabrication.com good stuff, good price and choice of colors
wytblur
08-05-2002 02:03 PM
