wheel spacers for 94 z28
Hey everyone. Im new to the group and have only had my Camaro for about a year. I just got some 2005 C6 Corvette wheels to put on (18"s in front/19" rear). But I realized today that I am going to need spacers for atleast the rear and longer studs. Havent really looked at the front to see if spacers/longer studs are needed for those also. I was hoping that someone might have done the same thing and could tell me the size of the spacer they recommend or any other possible suggestion.
hey welcome to the site! I ran c6 wheels on my camaro too and they looked awesome. You will need a billet spacer that is 1.25/1-1/4 and you lug pattern 5x4.75 or 5x4 1/4 same thing. just make sure there hub centric spacers. take a look on ebay i found a good deal on some for about 60 shipped. this will get the rims on there. oh and if your wondering what hub centric is, it's basically a wheel spacer or rim that will fit the diameter of you inner hub/brake rotor without play or movement. Go on ebay and search for camaro spacer 1.25 and you should be able to find what your looking for.
If you had posted on the "Wheels and Tires" forum, you would have seen a "sticky" post at the top, showing the details and end results of putting C6 wheels on a 4th Gen.
https://www.camaroz28.com/forums/sho...d.php?t=528858
10-31-2016 11:09 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
ChrisFrez
11-30-2014 08:41 AM
