where to buy lower contorl arm?
The aftermarket bushings are readily available.
Here is an example: http://www.summitracing.com/parts/MOG-K6178/
ES makes a poly set for the front. The lower bushing set has a revised design for the vertical bushing that eliminates the bind that often accompanies rigid poly bushings, using a spherical poly surface. I've had the ES fronts in the car for about 12 years now, upper and lower, and no problems. Nice solid feel to the front end.
I bought the ES Hyperflex Master Kit for the 4th Gen from Pace Performance Parts 12 years ago. Any shop that sells ES can get you the upper and lower A-arm bushings. This should be the front control arm kit:
http://www.energysuspensionparts.com...?prod=3%2E3164
