Where to get ajustable front coilovers
Looking to even out the front of the car. Sits low on passengers side by 3/4". Actually the whole front sits too low. Want to raise it about one inch. I have 17" cragars on it now but the rim/ tire combo is within 2 tenths of a inch of stock rim/ tire. Will be trading for stock rims and tires in a couple weeks. Could i just replce the stock DeCarbons and use my springs with a spacer?
Re: Where to get ajustable front coilovers
BMR makes a 1/2" shim that goes under the bottom of the shock, to space it higher off the lower A-arm.
http://www.bmrfabrication.com/F-bodySuspension.htm
Or, QA1/HAL makes adjustable ride height shocks for the 4th Gens.
Might be a better idea to find out why it isn't level. A worn sprnig will still be a worn spring if you use a shim or an adjustable height shock.
Yes you are right a shock wont afect ride height unless its stuck. I should have said coilover. I have some edlebrock adjustable coilovers on the way now. Hope they work!
A bent lower A-arm is a more likely explanation than a worn shock. Shocks don't affect ride height.
