where is it located??
Re: where is it located??
The rear shock is under the carpet. Pull the carpet back behind the rear seat and there will be a rubber piece there, pull it up and the nut is under there.
The front shocks are bolted in place in the same manner, but, you have to pull the top a-arm off to get to it. Those 4 bolts come through in the engine bay.
--Sean
--Sean
Henson071
09-21-2015 04:31 PM
