Who has needed a vacuum booster to better braking?
Old 02-26-2008, 06:00 PM
  #16
mdacton's Avatar
thats not a very big cam.
I would try a vac. resivor canister first.......What about your tune? I got a lot more vac. when you add some timine at idle
mdacton is offline
Old 02-27-2008, 01:54 AM
  #17
Kredz28's Avatar
Where should I mount it? And which vacuum line do i need to splice into? *note* The 2nd picture is the most recent...the car has no egr anymore...
Kredz28 is offline
Old 02-27-2008, 09:22 AM
  #18
mzgp5x's Avatar
I mounted my pump in the rear pan area. Plumbed to the Vac booster thru a rear pan area hole and under the car along the left side tunnel up to the vac booster. (Usered 1/2 alum tube and -8 socketless hose.) You may only need an aux surge canister as posted above. I did not have any vac (3" Hg.) @ idle with improvements on blower intake duct flow. Also, I had to wire a power source for the pump and choose to use a relay and toggle switch to engage relay. It helped to have a rear mount battery for power source. The other method is to go hydraulic. More expensive and more mod work to remove the Vac booster. b> (97ss 383 - D1)
mzgp5x is offline
Parts Wanted
03-17-2015 11:24 PM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
Red97LT1
9
12-17-2014 06:13 PM
NED4SPD
09-16-2002 10:45 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: Who has needed a vacuum booster to better braking?
