Who here lowered their car, but then later put it back to stock?
Old 01-29-2007, 11:50 AM
  #16
Sam Strano's Avatar
The trick is running a good shock, lowered or not..... I have a lot of customers running stock springs, mostly with Koni's since the shocks make the car work right.
apss.... you've hit your bumpstops, I know you have. They are in play with every spring set I know of. How hard you hit them, etc is determined by spring rate, height, shocks etc. If you look at your rear axle, you'll see the shiny spots where the bumpstops contact the axle housing.
Sam Strano is offline
Old 01-29-2007, 07:47 PM
  #17
Greed4Speed's Avatar
Originally Posted by Injuneer
Take a few turns off the spring seat nut on the QA1's.....
I don't have QA1's, but even this is a form of lowering instead of using a bigger tire to fill the wheel well.
Greed4Speed is offline
Old 01-30-2007, 12:35 PM
  #18
revtime's Avatar
Compromise, Its not a great word but its something you may have to do.
You can get the car looking exactly the way you want and know that there are places you just cant go or you can compromise a little and be able to drive the car wherever you want.
I am a drag racer at my very core but I have also had the car setup for handleing at one point, lowered, big wheels, the whole bit. I got tired of following my buddies around and being stranded in the street while they pulled into the local dairy queen. Scraping the crap out of the bottom of your car really sucks.
Good luck, hope you figure it out.
revtime is offline
Old 01-30-2007, 08:32 PM
  #19
It isn't anywhere near that bad for me. My car is daily driven so I'd never go that low. I'm also rolling on stock sized 17" wheels and tires.
Old 01-30-2007, 09:18 PM
  #20
robb4964's Avatar
Had my 99 lowered 2 inches. I went thrue a car wash and it ruined my steering rack. Snagged a line. They came off ASAP.
robb4964 is offline
Old 02-04-2007, 12:25 AM
  #21
stephenspann27's Avatar
I would like to stay with my stocks springs but my car is a 95 and the body has 190k on it. Do you think the stock springs are at their service limit?
stephenspann27 is offline
Old 02-07-2007, 01:03 AM
  #22
revtime's Avatar
190k? Yeah they are prolly pretty wore out by now. You should be able to find someone with relativily low mile springs for sale because they have lowered the car.
Good luck.
revtime is offline
Old 02-09-2007, 09:30 PM
  #23
blackztpi's Avatar
can't you just mount some shocks on the lower shock perch on the rear to level the rear with the front?
blackztpi is offline
Old 02-10-2007, 01:30 PM
  #24
Rear ride height is controlled by the springs, not the shocks. Unless you've done a coil-over conversion.
Injuneer is offline
FredM
12-18-2014 01:40 PM
USAirman93
11-24-2014 03:37 PM
Mad_Ice
07-29-2002 09:44 PM
Joshs99BlackBeauty
07-27-2002 04:22 PM
Manaz101
07-18-2002 09:39 AM
Quick Reply: Who here lowered their car, but then later put it back to stock?
