Will 7 quart deep oil pan hit ground if i lower
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
I am thinking about lowering my car. But I also just put a 383 stroker in and I got a 7 quart deep oil pan on it. So if i lower my car like from 1" to 1.5" will the pan hit the ground.
Let me know
Let me know
Re: Will 7 quart deep oil pan hit ground if i lower
If not, it would be real close.... Take a tape measurement just behind the front wheel to the ground, then subtract 1 1/2 inches.. That will give you a base line, somewhat.... Then measure at the oil pan to the ground and subtract 1 1/2 inches... This should give you a guide line before the drop....
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
stockssn2o
05-25-2015 08:54 AM
