Will C5 brakes fit behind Torque Thrust Rims
I have a 95 Camaro and I would like to get a set of C5 brakes and bb brackets. I heard not all 17 inch rims fit over the C5 brakes. Has anyone done this brake swap and used 17inch Torque thrust ll rims.
This kit requires a minimum of a 17” wheel for clearance. All 1996 and newer 17” wheels will fit correctly with this kit. If you are running a different wheel set up please research fitment before purchasing.
From our research we have found the following wheels will NOT clear with the conversion kit, they may clear with the correct wheel spacers:
1. Enkei Win- 17” x 9.5”
2. 93-94 SLP Firehawk wheel- 17” x 9”
3. Borbet Type T- 17” x 9.5”
4. Forgeline RS Reverse Rim
5. Torque Thrust II
http://www.umiperformance.com/catalo...roducts_id=160
5. Torque Thrust II
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
CARiD
01-27-2015 06:27 AM
