Will WS6 springs from an LS1 work on an LT1 car???
Re: Will WS6 springs from an LS1 work on an LT1 car???
Yes. The springs are interchangable.
I believe though that the ws6 springs are 360in/lb while the stock lt1 front springs are 310in/lb. The rear springs should be the same. I doubt the spring rates will be that noticeable. Someone else will have to back me up on that statement. I'm not 100% sure. If the WS6 springs are not an upgrade over stock LS1 springs, then they woulud actually be softer than what comes on a LT1 car.
yes they would work, but remember: the ls1 cars have an advantage in weight. the engine weighs about 100 lbs lighter due to it's aluminum block. but if you're willing to try the experiment, i have a new, barely used (about 3000 mi) set of front only slp springs. 50 bucks and shipping and they're out the door.
mspennyhughes
11-28-2014 03:22 PM
07-04-2005 05:00 PM
