Z28 rear frame question
Old 06-04-2006, 09:06 PM
vortecblazer4wd's Avatar
Wrecked my '95 Z28 Convertible other day, hit into cement barrier. Body isn't bad, but rear end of car is pretty bad. The hub\rotor broke off from the axel. Torsion bar where it mounts to the frame is bend, and the part of the frame that comes down to where torsion bar connects is bent. I can replace the rear end, but is it possible they can repair the frame? Is this worth fixing, or better to part out car? Engine and body is in good shape otherwise. Your thoughts?
vortecblazer4wd is offline
Old 06-05-2006, 07:19 AM
87DJP2001's Avatar
Re: Z28 rear frame question
No frames on these cars, all Un-Body consturction. Only a good body shop with body aligment machine can answer your question.
87DJP2001 is offline
Patricklt1
04-24-2015 06:29 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
07-04-2005 05:00 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Brent94Z
03-21-2002 04:44 PM
Quick Reply: Z28 rear frame question
