1994 Camaro will not start???
Old 12-16-2008 | 07:07 PM
BLWNLT1's Avatar
My step son has a 94 3.4L camaro it will not start for nothing... I changed plugs, and wired cranked over and sputtered for a few seconds and died. Has not even hinted at trying to start after that... Any suggestion will be helpful.
You can hear the pump turn on then cut off after 4 -5 seconds. Also smells like raw gas when cranking over...
Old 12-16-2008 | 10:07 PM
andysc's Avatar
Sounds fuel related to me, possibly a bad fuel regulator. Get a fuel pressure gauge, and see what you find.
tia
Andy Schuck
Old 12-17-2008 | 09:55 AM
BC2002SS's Avatar
test the fuel pressure at the fuel rail. the pump could run but not build pressure
Old 12-17-2008 | 05:17 PM
camaroLevi's Avatar
Wink first and for most
check the fuel pump relay and ur ignition relay/ module....then do the fuel pressure check ...easiest thing to do is check ur relays...had the same problem but fixed with the new relay input
Scottylt1
01-08-2015 02:48 PM
Scottylt1
12-04-2014 12:31 PM
dreamer1q
07-24-2002 04:39 PM
dreamer1q
07-09-2002 05:37 PM
dreamer1q
07-08-2002 08:47 PM
Quick Reply: 1994 Camaro will not start???
