94 camaro
94 camaro
Car = 1994 camaro RS 3.4L SFI -Automatic Transmission
hey guys i have an issue when im on the freewway in Drive @80mph my rpms= 3000
What the heck thats a little high no?
also my gas guage seems to be off how do i fix that
also my low oil light will come on every once in a while when i start the car but when i have my uncle and all the other dudes on my block check my oil they say its fine and teh guys at brake masters whe n i got my oil changed said it was mkay 2
thanks in advance
thanks in advance
I think 3000RPM might be a little high for 80mph. I think i do 80 at around 2500 - 2700RPM. And for your gas gadge, it is probably working fine. Usually, the first 1/4 of the gas lasts a long time - 200 miles, then after that, it drops pretty fast. All 4th gens are like that, it has something to do with the way the gas tank is shaped i think. If thats what your refering as the gas gadge problem, then its probably fine.
I know the dealer sometimes calls me before they fix something. I would take it to the dealer and clearly specify that you want them to call you after they have determined the problem. The dealership I take my car to also charges by the fix not by the hour so they wouldn't charge you to look at it. I don't know if all dealers work this way but my local one does.
Originally posted by kickinthehouse
my camaro is a 94 would a dealer ship still wanna takea look at it ?
Originally posted by 99blackSS
Then when they call see what the problem is and how much it will cost to fix it.
I really don't like the dealerships...especially for non-warranty work.
