anyone have a hood?
Old 05-15-2006 | 09:16 PM
jonny72888's Avatar
anyone have a hood?
like most i have the hood with the 2 scoops... but does anyone have the type without any? i want one of those so i can make a ram air.
do you think i should just get a SS hood?
Old 05-16-2006 | 12:13 AM
shock6906's Avatar
Re: anyone have a hood?
I've never seen a stock camaro hood without the scoops, at least not for the 93-97 body style. 98+ has no scoops on it, but they won't work for the earlier year 4th generations. I think an SS hood on a V-6 camaro opens you up to a lot of ridicule.
Old 05-16-2006 | 06:45 AM
jonny72888's Avatar
all i want is some real scoops!
is there any way to make the ones i have work? like any kits out there?
Old 05-16-2006 | 10:29 AM
shock6906's Avatar
you can take the black plastic grills out, get a dremel and cut away the fiberglass behind the plastic. after that, get some aluminum mesh. Most people use gutter guard for this, its less than 2 dollars at home depot. bend it and shape it to the opening and then attach it. the best way to get it to stay there is most likely going to be fiberglass. although this will make the scoops functional, it's not going to be for any specific purpose other than getting a little outside air into the engine bay. i've never seen a kit that turns them into ram air scoops, and truthfully, it'd be a big kit and would take up a ton of room under the hood if there was one.
Old 05-16-2006 | 10:45 AM
FuryZ28's Avatar
They'd make good heat extractors, like the Firehawks have...
Old 05-16-2006 | 05:54 PM
jonny72888's Avatar
i think im going to do that
what about jusr making holes in the black plastic? is there anything behind them?
Old 05-16-2006 | 11:47 PM
shock6906's Avatar
you can't just drill the holes in the black plastic, they're nothing more than trim pieces. you can remove the hood liner to expost the scoops (they pop out) I can't remember if they're nuts and bolts or whatever, but you'll see when you get there. pop em out and then the black plastic pops out. get your dremel ready and hack away. be careful...go small and then trim away the excess. you can always take more off, but you can't add back to it. well, you can but it's a lot more work.
As for that, heat extractors usually face backwards, not forward into the wind.
Old 05-17-2006 | 07:32 AM
jonny72888's Avatar
well these will make good air forced in to nothing scoops
Old 05-17-2006 | 10:56 AM
shock6906's Avatar
Well, you might get a little extra cool air under the hood slightly lowering engine bay temperatures, but I wouldn't expect too much benefit from it. Nothing other than it looking a little cooler. I've seen it done once and it looked good, wish I could remember where it was that I saw it so I could link you.
Old 05-17-2006 | 08:25 PM
jonny72888's Avatar
dont worry about it.
im going to do it next weekend. i just put a flowmaster american thunder on and it took 5 hours!! 3 1/2 apent trying to take the old one out ( all i had was hand tools) so im done with the car for a few days
ill post up a DIY when i do the scoops so you all can see how i did it
Old 05-18-2006 | 03:44 PM
Garcia95's Avatar
I think a SS hood will look cool.
Stephen68
10-16-2015 03:50 PM
football4life
10-04-2015 07:48 AM
CARiD
09-30-2015 05:44 AM
gearhead3
Parts Wanted
09-16-2015 08:18 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: anyone have a hood?
