Camaro Chugin!!!
Camaro Chugin!!!
Ok say when im going 70 and hit the gas half or all the way down it starts to chug and sometimes chug bad! Like its getting no gas at all! So i changed my Fuel Filter and also my air filters just to make sure and still is doing the same thing! So say i gun some 93 octane gas and some injecter clean it runs great but with regular gas its horrible! this just recently started happening and never did this before,,,,,,, is my engine going?????
Sounds like you're getting detonation with the lower grade gas? Do a search for detonation here on the boards and you should come up with some helpful links explaining what some of the problems may be causing it. Does your exhaust ever blow blue smoke when you first start it?
Originally posted by Jaswir
no some times it blows white smoke and some times it doesnt
blue smoke= burning oil if its only a bit at startup dont worry if its when your driving then yes could be rings/valve seals
white smoke for the first 20mins+ when you start your car can be normal from condensation in the exaust
F'n1996Z28SS
08-23-2023 11:19 PM
CARiD
01-14-2015 04:00 AM
ChrisFrez
12-07-2014 06:01 PM
NewsBot
12-03-2014 12:30 PM
