Intake manifold
Intake manifold
i have a 2000 Camaro 3800 mounted in my 1977 MGB, and was looking at where the thorttle body is mounted. it looks like i'm going to have some problems with a radiator gettting put in there. are there any intake manifolds taht will alow me to switch where the throttle body/air intake is located on the engine? i was looking at my 1989 Oldsmobile, which also has the 3800, and the intake comes from the other side. same thing with my 2003 MonteCarlo SS, which has the 3800 also. any help would be appreciated.
matt
matt
Re: Intake manifold
The supercharger will also move the airintake to the rear. But you could still run into a pulley/radiator problem.
You should be ok with any of them, but I CAN'T say for sure. Some where in the 3.8's history they changed designs on the top end.
Re: Intake manifold
thanks for the help guys.
matt
Re: Intake manifold
Originally Posted by Tarnsman
Have you looked at the upper intake manifold from a 95-98 3800 F-body? It is different from the 2000.
matt
Re: Intake manifold
Here are some iffy pics of my friend's '98 camaro....they will give you an idea of the manifold difference (it points down and towards the driver's side.
http://www.cardomain.com/memberpage/659591/3
- Justin
- Justin
07-04-2005 05:00 PM
