loss of power in low rpms??
hey, i've got a problem during acceleration and in lower rpms. This doesn't happen all the time but when i begin to accelerate off the line, my car will suddenly just lose power, until i get going a little bit faster. It also does this when i'm driving at normal speeds and i give it a little gas it acclerates a little rough and sluggish. If anyone knows what this could be, i would really like to know cuz its starting to **** me off. Someone suggested that it could be my fuel filter so i changed that, my plugs and wires were just recently done. Any advice would be greatly appreciated!!
Ah... fuel injectors could be partially clogged? I have had this happen on my 96. Cleaner gas additive wasn't enough to clean them so I took it to a dealership and had them clean them. They cleaned the throttle body too and it helped my car a lot.
Might not be what your problem is but it could give you more ideas.
Could be injectors, generally dirty fuel system. I had my full system cleaned out, and cleaned out the throtle body, it wasnt untill i changed the fuel filter that the problem was cleared up. Sometimes so blockage in the fuel filter can cause low RPM stumble.
slothgrant
08-22-2002 03:01 PM
