Service Engine Light Question?
Old 07-13-2003 | 11:45 PM
Pabz's Avatar
Question Service Engine Light Question?
OK, I put in a cheap intake chip recently into the air intake sensor. But to keep it in i had to unhook it from the socket. And i drove around without it plugged in. Then after a couple of days the service engine soon light came on. I looked under the hood and saw that it fell out of the sensor. SO i plugged the sensor back in. ANYWAYS.... I was just wonderin that will the light come off now that i did that or do i have to do somethin special to get it to come off.
Old 07-14-2003 | 11:25 AM
ImportKILLER's Avatar
Assuming that the SES was caused by the sensor being unplugged, it should turn off after a couple miles/starts if it hasn't already.
I don't know if AutoZone has just the scanner or if they can clear it as well...
Old 07-14-2003 | 12:40 PM
1fastV6's Avatar
unplug the battery for 10 minutes and throw away that waste of money mod you bought
Old 07-17-2003 | 12:18 AM
sick94's Avatar
Check out www.installuniversity.com, and click on install mods, they will show you how to make that sensor for about 25 cents, plus how to clear your code problem. They have great instructions for it and how to seal it up so it won't fall out. Those chips are good for the money, even if it is like 1 hp or something, you can feel the difference. l8tr
bfmv13trivium
01-14-2015 09:57 AM
01-05-2015 07:14 PM
cmdeshon
12-27-2014 10:06 AM
mspennyhughes
11-28-2014 03:22 PM
07-04-2005 05:00 PM
Quick Reply: Service Engine Light Question?
