squealing front brakes....need help
i installed a set of rotors on my car about 1000mi ago, they are still squealing apon braking at low speed. i bought a tube of 'disc brake quiet' 2 questions:
where do i apply it
how much do i use
if anyone has used it let me know any info is greatly welcomed. i have learned a valuable lesson when it comes to doing my repairs after my last spark plug issue. and that is, ask the members on this board before doing anything!
where do i apply it
how much do i use
Sorry to tell you, but you are gonna basically have to do it all over again. The lube you speak of, is to be applied liberally onto the back of the brake pad itself. The only way to get to the back of the pad, is to take it out of the caliper. The lube I use is a thick liquid with the consistency of watery toothpaste. Anyway, wherever the pad touches the piston, apply the lube. The will prevent sqeaks.
-Adam
-Adam
96SilverRam
11-20-2016 11:19 AM
