top speed govenor
Mine is set to the standard 115 MPH too. And I could have disabled it with computer work, but for now I chose not too. Mainly because you don't want to be pulling any speed in which your tires are not rated for. That's a real easy way to kill yourself. Also, the stock suspension on the V6 is the weakest of all F-bodies. Anything more than 115 (whether you choose to do it or not) just isn't safe.
Now after I have a suspension and Z or Y rated tires, then I'll pull the govenor off.
And naw, it won't harm the car, I bang the govenor at least a couple times a week.
harming the car should be the least of your worries though, 115 MPH is a fast speed, even if it doesn't feel like it. One bump in the road and its lights out for you and anyone else around you. Personally I've had a couple blow-outs at 75-80 MPH, and I've seen those end in fatalities. I can't imagine losing a tire in excess of 100.
Be smart and never exceed your equipment.
Originally posted by Killerjello
i wouldnt worry about it, you dont need to be going that fast anyways
canbaufo
02-24-2015 10:27 AM
NewsBot
01-11-2015 06:10 PM
mark0006
12-25-2014 09:50 PM
