tough choice?? i need advice...
should i go through the hassle of changing my head gaskets. i possiblly have warped heads also(if i take it in to a shop it will cost at least $900 in labor alone) or should i just find a used engine and swap it. my current engine already has over 100k miles. what are your opinions??????
Personally I would probably find a new engine to swap in if you cannot have much downtime with the car. If you have a little extra cash and another vehicle to drive, then you may look into rebuilding your current motor with a few performance goodies, such as a cam, maybe have the heads ported, etc.
Good luck,
Joey
Good luck,
Joey
08-24-2015 06:41 AM
