st.louis local tuner for 94-95 lt1
Hi everybody my name is Beau some of you know me I am going to offer tuning and diagnosis to 94-95 obd1 lt1's. I have programmed a few local cars and tons on my own car. I am going to offer 3 simple plans all plans come with a life time of changes or reviews for a small fee. Is your stock car not running as good as it used to. I can help fix idle issues and help improve you gas mileage. If you need lt1 work done to your car call me I can get it done cheaper than anyone else.
Diagnosis- 50 dollars
- Code scans
- Wot logs (a review of timing, fuel, and spark)
- Sensors condition
- Simple car inspection(header leaks fluid leaks etc...)
Diagnosis and computer changes- 100 dollars
same as above but will make changes to pcm. I can change any settings you want just contact me
- High stall issues fixed in a4
- Different injector size/offset calibration
- Knock retard desensitizing
- Idle adjustment
- Rev limiter adjustment, disabling/adjustment of the speed limiter
- Ported heads/headers/exhaust/aftermarket camshaft tuning
- Shift points/shift firmness/shift kit/different stall adjustments (A4)
- Fan kick on temperature adjustments
- Skip shift elimination (M6- Transmission conversions (A4 to M6, A4 to Th350, Th400, etc)
- Speedometer/Automatic transmission adjustments for different gear/tire size
- Premium gas tuning
- Larger throttle body adjustments
- Different engine displacement
- Disabling various devices/sensors/codes/etc
computer programming with wide band- 250 dollars
- Innovate motor sports wideband with rpm logs
- Street tuning
- Dyno tuning (I do not have a dyno sorry but will meet you at one that you paid for)
NOTE: if you want wideband services you need to have a o2 bung installed before cats, prior to coming out. will only cost about 50 bucks the bung is only 8 dollars
I can make house calls if the car cant come to me. I can make changes or review your car again (if you made head or gear changes etc...) for 20 dollars a visit. I work midnights so days and evenings will work fine. My cell number is 618 578-8868. I am not looking to make much money off of this just pay for my equipment and meet more members.
- Code scans
- Sensors condition
- Idle adjustment
- Street tuning
