GM techs
Old 12-21-2004 | 12:25 PM
BA383TA's Avatar
GM techs
Are there any GM tech's in the dallas area that could help me. I recently put a 355 motor in my 95 formula. The car spins over but wont start. I looked for the cause and the injectors are not firing. I checked with a noid light to make sure. I checked all the grounds and they are all present and they are good and they are. I had the VATS deleted and thats the only thing else that i can think of that would make the injectors not fire. Bryan with pcmforless.com is trying to help me out but so far we havent come up with anything. Im stuck and I wanted to know if anyone has had the same problem and what to do to fix it. I dont think the fact of it being a 96 motor and A4 tranny make any difference. The pcm worked before and I even tried another computer and same thing. Please help. Thanks, Bill
Old 12-22-2004 | 05:54 PM
whitehooptie's Avatar
Re: GM techs
Dumb question, but did you check the fuses in the panel? And are you sure the VATS delete is done properly? Does the fuel pump turn on when you turn the key on?
Old 12-22-2004 | 06:02 PM
BA383TA's Avatar
Re: GM techs
Just figured it out. Corroded sensor and plug on the opti so i just put in a new opti in since i had one. Car fired up and sounds great.
bill
Old 12-23-2004 | 03:18 PM
jakesnake123957's Avatar
Re: GM techs
All right man ,sometimes the little stuff is a pain in the rear.
Boss002
01-20-2016 12:17 PM
Fatdog2
09-16-2015 11:04 PM
RX Speed Works
09-11-2015 03:31 PM
Boss002
07-24-2015 10:47 AM
Quick Reply: GM techs
