00' Z28 rims on a '95??
Don't know if this has been covered in the past, but I'm swapping my gungy rims out for a set of stocker '00 Z28 rims. As I am unfortunately finding out, there is a lip inside the hub mount of the rim that is not allowing it to fit on the rear axle hubs. They fit fine on the front. Has anybody just ground the lips off without problems?
Thanks.
Thanks.
Re: 00' Z28 rims on a '95??
me too for '97's on my '95. used a dremel with the steel grinding wheel that looks like a little turbine. tip: keep the dremel moving steadily, don't try to take out a level at a time.
BandDirector Blk98ZM6
02-20-2015 07:42 AM
