17 in rims
Re: 17 in rims
Doesn't matter what engine you have, or whether its a base model. All 4th Gen's have the same 5 x 4.75" (120.65mm) bolt circle, and the same wheel well dimensions. Anything you see on a 4th Gen will fit your car. The stock wheels on the SS and WS6 coupes were 17 x 9.0" with 275/40-17 tires.
If you go to the "stickies" at the top of the forum topic listing, there is info on the width vs. offset combinations that will fit on a 4th Gen.
I have 17x9.5" front and 17x11.0" rear:
http://www.injuneer.com/images/photo.../IMG_0061a.jpg
