295/35-17 and 315/35-17 on my z28
Old 07-27-2008 | 12:08 AM
zrultima's Avatar
I am wondering if i can do this I want to buy these tires ASAP but i always see 275 instead of 295
Old 07-27-2008 | 01:35 AM
zrultima's Avatar
anyone
Old 07-27-2008 | 02:25 AM
bluz28's Avatar
The reason you always see 275s is because nobody makes a 295/35/17 street tire
Also if they did I don't think you would want to run a tire 1/2" shorter than a factory height tire, IMO!
275/40/17 = 25.66"
- 295/35/17 = 25.13"
_______________________
= .53"
Old 07-27-2008 | 02:27 AM
carguy2112's Avatar
315s can be done.
https://www.camaroz28.com/forums/sho...d.php?t=312442
Injuneer has 315's on the back of his.
http://www.injuneer.com/images/photos/Frt34vwD.jpg
Old 07-27-2008 | 11:08 AM
zrultima's Avatar
295/35-17 do exist and have been done i ask on streetfire.net and theres a couple of ppl with this mod. Now I want to try it but is there a mod so they can fit
Old 07-27-2008 | 11:39 AM
I checked both Tire Rack and Discount Tire Direct. The only 295/35-17 tire I could find is a Hoosier A6/R6 road racing tire. Is that what you are planning on running? If so, its definitely not a tire you would want to run on the street, in the wet. The small diameter will only make the already too large gap between the front fender and the tire look even larger.
If you are so intent on huge front tires, go for 17x11's with 315/35's on them. There was a thread recently showing several examples.
Now.... all of this ASSumes you are asking about tires for a 4th Gen. But you never bothered to tell us what generation Z28 you are asking about.
Old 07-27-2008 | 12:28 PM
carguy2112's Avatar
No one on streetfire told you a 295 would go on your car. For that matter, no one on streetfire said anything at all about the 295, except me. The only thing I said is no one makes it.
BTW Injuneer, his is an 01 Z28.
Old 07-27-2008 | 02:04 PM
bluz28's Avatar
I only said they don't exist in a street tire.
Your question was vague, so I inferred.
Why not also go with 315s in the front, as already stated.
Old 07-27-2008 | 03:12 PM
zrultima's Avatar
well no i spoke to someone that had a camaro well so i guess i should go with 275 for the front huh??? thank u car guy ur so helpful
Old 07-28-2008 | 02:02 PM
slomarao's Avatar
everyone makes a 285/40/17. Just a little bigger.
295/35/17 is racing rim size. your not going to find any street tire is that size. Either run a 285 or move up to 18's which have 295/35 tire.
F'n1996Z28SS
08-23-2023 11:19 PM
Renegade Toker
01-23-2015 10:27 PM
NewsBot
01-11-2015 06:10 PM
01-05-2015 07:14 PM
cmdeshon
01-04-2015 11:15 AM
Quick Reply: 295/35-17 and 315/35-17 on my z28
