C5 18x9.5 rims won't fit in back
Old 09-15-2005, 03:11 PM
  #31
Grims's Avatar
Re: C5 18x9.5 rims won't fit in back
im thinking about buying longer wheel studs and high quality spacers...I really hate to use a spacer...but its that or or new wheels.
Grims is offline
Old 09-15-2005, 03:14 PM
  #32
robertotrevino's Avatar
its weird cuz they have 18x9.5 with 54mm offset they sell them, just no in that package
robertotrevino is offline
Old 09-15-2005, 03:15 PM
  #33
Grims's Avatar
call them and ask them to sell them to you in that way. Also, mine seem to be very ehavy...I don't think their really aluminum
Grims is offline
Old 09-16-2005, 11:04 AM
  #34
Originally Posted by robertotrevino
what about the ppl that have the z06? they are 56mm offset but 10.5 in wide...
that means that from where the wheel sits its 10.5/2+56/25.4 inside and 10.5/2-56/25.4 outside so you have 7.45Inches inside and 3.05 outside
for the 18" 9.5 wide with 65mm offset you have 9.5/2+65/25.4 inside and 9.5/2-65/25.4 outside.... so 7.31 inside and 2.19 outside...
the Z06 wheel with 56mm offset actually sits further in than the C5 with 65mm...
I'm confused
You may have the wrong dimension for the C5 Z06 wheel.... according to a table of wheel sizes in VETTE magazine, the C5 Z06 wheels are 10.5" wide, 58mm offset.
And, you're ignoring the width if the flange that holds the tire on the rim. Wheel width is measured where the tire beads seat, not at the outside edge. You need to add about 0.45" - 0.50" to each side for that.
10.5" + (2 x 0.45") = 11.40"
58 / 25.4 = 2.28"
Backspace = (11.40 / 2) + 2.28 = 5.95 + 2.28 = 7.98"
A 7.98" backspace puts the inside edge of the tire against the inner fender. Those of us running the 17x11 50mm ZR1 wheels, with 7.93" backspace, generally have to hammer the fenders.
For the 9.5" wide wheel with 65mm offset:
9.5" + (2 x 0.45") = 10.4"
65 / 25.4 = 2.56"
Backspace = (10.4 / 2) + 2.56" = 5.20 + 2.56 = 7.76"
That backpsace gives you almost 1/4" more clearance for the inner edge of the tire. It will look "sunk" into the wheel well. But with a reasonable size tire, should clear.
And the 56mm offset on the 9.5" wide wheels solves all the problems, giving you only a 7.40" backspace.
Injuneer is offline
Old 09-16-2005, 11:21 AM
  #35
Oh, I see, thanks.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Jlo
02-03-2015 09:41 PM
Kato
01-26-2015 09:21 PM
12-04-2014 11:56 AM
Quick Reply: C5 18x9.5 rims won't fit in back
