Can I run 17 x 11's in the rear on my 95?
Just checking to see if I can run 17x11's in the rear on my 95Z. May have a chance to get some TT2's and thought I would ask here first. I know some people had a problem running 315's. But I would be running 285's.
I am sure this is a common question, and I feel like I can get away w/ it, but I can't remember if there is something I have to do first?
Hope someone can let me know pretty quick![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Thanks!
Thanks!
Re: Can I run 17 x 11's in the rear on my 95?
http://web.camaross.com/forums/showthread.php?t=312442
I have them on my 94 vert with 315 35's out back with no changes made. Noticed a slight rubbing on certain turns, that's it.
yes they will fit but to ensure no rubbing at all you must cut the bump stops some and massage the rear fender wells with a big [edit] hammer. Massage sounds better than beating them in. Then get some undercoating and recoat where you hit and it looks factory. I have them on my 95'Z.
NOTE from Moderator: Do not override the language filter.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
squarehead
11-21-2014 08:02 PM
