NEED HELP!!! C6 RIMS!!! will they fit?
Old 04-22-2012 | 02:50 PM
Murphdizzzl's Avatar
on my 2001 camaro v6 i have 20x8.5 with an offset of 15 with 255/35r20 tires and they rub when i turn and people r telling me that i can put c6 18x9.5 with an offset of 58 which is obviously wider and they wont rub i dont c how this is? and if this is true what size tires should i get? thanx for the info
i need info by monday please!!!
Old 04-22-2012 | 05:45 PM
Re: NEED HELP!!! C6 RIMS!!! will they fit?
Will they fit on what car?
Add a "Signature" with basic info about your car - year, model, engine, trans and any major mods.
Old 04-22-2012 | 06:31 PM
2001 camaro v6
Old 04-22-2012 | 11:18 PM
The 15mm offset is your problem. A small offset moves the wheel/tire outwards, a larger offset moves the wheel/tire inwards.
An 8.5" wide wheel with a 15mm offset would result in a 4.2" "frontspace" and put the outer edge of the tire about 1/2" outside the fender. That would account for the tire rubbing.
The one factory C6 wheel that is 18x9.5" that I am familiar with is the Z06 front wheel, with an offset of 40mm. That would pull the outer edge of the tire in about 1/2" and move the inside edge of the tire closer to the stock position. Might still rub on the fender with the steering turned to full lock, or if you hit a very hard bump.
Z06 Wheel:
I think about 2010 they added an 18x9.5" wide front wheel for the Grand Sport option, but I don't have the offset for that. I did find one unverified reference online that they are 57mm offset, which would work:
If you want factory C6 wheels, those are the two options. If you are looking for aftermarket/reproduction C6 wheels, they are available in several styles, widths and offsets. With a 9.5" wide wheel, the ideal offset is in the range of 45-56mm.
Old 04-22-2012 | 11:57 PM
here is the link if u click on specs it says the offset is 58
and about the rubbing can i put a spacer?
Corvette C6 Wheels
LD Kirk
04-30-2015 08:54 AM
04-03-2015 10:54 AM
mschmidt33
03-15-2015 07:20 PM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
Kato
01-26-2015 09:21 PM
Quick Reply: NEED HELP!!! C6 RIMS!!! will they fit?
