New Wheels
Old 10-10-2006 | 08:49 PM
sills1's Avatar
New Wheels
Here are a few pictures of my car with the new Torque Thrust Ms (Anthracid) Enjoy
One with the wife
Old 10-10-2006 | 09:00 PM
DustinZ28's Avatar
Re: New Wheels
such a sick car bro, love it. keep it clean!!
Old 10-11-2006 | 09:29 AM
Re: New Wheels
Looks great!
If you could add info regarding the wheel size(s), wheel offset(s) and tire size(s), it helps people to understand better how a particular wheel might look on their car, with similar dimension/sizes.
Old 10-11-2006 | 10:11 AM
Ponykillr's Avatar
Re: New Wheels
Where did y0ou buy those wheels? I got a set off ebay but I want the larger wheels like you have on the rear. Mine are 17x9 all the way around.
Old 10-11-2006 | 03:09 PM
sills1's Avatar
Re: New Wheels
http://www.ls1tech.com/forums/showthread.php?t=582262
Old 10-11-2006 | 04:04 PM
Re: New Wheels
Copied from that thread:
17x9 +45mm
17x10.5 +44mm
With the +44mm offset on the 17x10.5's, the outside of the wheel will sit almost exactly where the 17x11 50mm ZR1's sit. It will have 1/2" less backspace, so it should avoid the issues of having to cut the jounce bumper bracket or hammer the inner fender liners.
And your tires are 275/40-17 front and 315/35-17 rear, I assume?
Tire Rack also lists those wheels. The correct color is "Anthracite" according to all the other sources except "Tom's" (he corrects it later in the thread).
Old 10-11-2006 | 04:32 PM
sills1's Avatar
Re: New Wheels
Ok, well.....If you look on the manufacturer's site, the name of the color is Anthracid. You are correct about the size tires I am running.
force10
08-10-2015 08:30 AM
30th Anniv Z28
08-01-2015 10:39 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
jasonduaine
06-04-2015 09:29 AM
Quick Reply: New Wheels
