Polished Z06 Replacement
Old 07-25-2009 | 12:06 PM
LT1Mandel's Avatar
Exclamation Polished Z06 Replacement
I'm on a time crunch and need to locate an 18x10.5 C5 Z06 wheel in polished aluminum to replace one of mine that was damaged in a collision.
Originally purchased from OE Wheel Distributors, but my collision center tells me they only have chrome in stock. Does anyone know a vendor that would have this wheel in stock right now that I could purchase from?
If I strike out, is there any significant problem with sticking a chrome one on there in its place?
Old 07-25-2009 | 02:56 PM
yy's Avatar
yy
No significant problem, just that the appearance may seem a bit awkward as polished and chromed wheels look that much different.
Old 08-11-2009 | 02:56 PM
LT1Mandel's Avatar
Question Option #2
I've now found a polished replacement wheel, but the manufacturer says this wheel has a +58mm offset versus +56mm for my other three. Is this a significant problem?
I'm faced with the decision whether to get a chrome wheel in the same size or a polished wheel with a +2mm offset difference. Which is the better call?
Old 08-13-2009 | 01:51 PM
LT1Mandel's Avatar
Can anybody offer advice?
Put 1 chrome wheel with 3 polished wheels?
OR
Buy a polished wheel w/+58mm offset while my other 3 are +56mm?
Old 08-14-2009 | 09:21 PM
yy's Avatar
yy
I'm not a wheel expert so my advice would be to ask one to see what the difference is between the 58 and 56mm offsets. If the offset is actually the mm, then I would assume that the 2mm difference would not be noticeable.
Old 08-17-2009 | 03:46 AM
Procharged94Lt1's Avatar
grab a tape measure and look at how big 2mm is...i highly doubt anyone will notice it...
You will notice a chrome wheel way before you will notice 2mm difference.
10-31-2016 11:09 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
Roadie
02-16-2015 10:34 AM
hotrodyou1
12-20-2014 10:05 PM
dansam
07-20-2002 01:10 PM
Quick Reply: Polished Z06 Replacement
