Tires
Old 03-27-2011 | 12:03 PM
Bob K's Avatar
Tires
My 2000 Z28 came stock with 235/55/16's. I still have stock rims. Will the 245/50/16's be OK. The door sticker says 235/55/16.
Whats the difference ? What will I feel / how will the car sit..higher..lower.
The 245's are more abundant...better/more choices than the 235's.
HELP !
Old 03-27-2011 | 04:05 PM
95TA04GOAT's Avatar
Re: Tires
You won't have a problem with the 245s. The 245s will actually be just about a 1/2" shorter but that's pretty marginable. The speedometer as a result will be reading about 2% faster than you're actually going which again, isn't terribly bad. You probably won't notice the car sitting a 1/4" lower than it is now, and probably won't notice a difference in ride either.
Old 03-27-2011 | 06:23 PM
Re: Tires
We have a "Wheels and Tires" forum. I'll move the post there.
Old 03-27-2011 | 10:25 PM
JakeRobb's Avatar
Super Moderator
Re: Tires
In your other thread, you said you were looking at General Altimax. With a cheap tire like that, you'll notice basically no difference.
The advantage of going to 245s is that it opens up options for higher-end tires. If you do that, then you might notice a difference.
Novo
Wheels and Tires
14
10-12-2015 12:20 PM
Daluchman1974
09-11-2015 07:12 AM
scottcba1
09-08-2015 10:52 AM
rideordie
09-07-2015 09:22 AM
Slayer
07-04-2015 04:06 PM
Quick Reply: Tires
