Will 97 Z28 rims fit on a 89 IROC.
Re: Will 97 Z28 rims fit on a 89 IROC.
depends on how far you need to move it. the bolt pattern is the same but they are going to sit inside of the wheel wells quite a bit because of the different backspacing and will rub on everything, not sure if they will even go on. If you need to move it 10 feet you might make it work, but I wouldn't drive it anywhere.
To make this work you need like 2" spacers. Without them the tires will hit the inner fender well on the rear and the suspension components on the front, like the steering arm (knuckle) where your tie rod connects and the shock strut.
You must have a friend with an s-10 blazer or pickup or an older camaro, or at least a spare that would fit. Surely someone you know would have one. If you still have it the spacesaver spare out of your 4th gen would work.
Wilson
07-21-2002 05:08 PM
